| Message |
So i just finished my Na-TT swap. Fully rebuilt TT engine. Dropped it in, got all the IC piping finished. Installed gauges and A/F controllers etc. No oil pressure. ???The gauge I installed shows 11psi. And, it is really loud when on. You can hear the valves ticking. My mechanic says its the oil pan. It has a huge dent in the bottom of it. Says it is probably not allowing it to suck up oil correctly. Is this true ? Could just changing the oil pan fix the problem? It's going to cost me $300 to change the pan, plus the cost of the pan. Any other suggestions ?? Thanks
